Michael 4 problems..
VitachickVitachick Posts: 135
Today tried to open M4 previous scene in Poser 2014...Would not import..
Ok..Opened new window but then wasn't able to save to my desktop folder..
Now opened Daz3...Tried to open M4...this is the window showing the
error...Have no clue why etc...Also cannot open in Daz 4.6...
Anyone have a clue what happened???? All the saved characters :(>:-(
1600 x 900 - 173K
  • Richard HaseltineRichard Haseltine Posts: 100,841
    That's the power loader script - it should run when you load the Michael 4 figure fiel into DAZ Studio. The face that you are seeing the files in a DAZ Studio format content directory, rather than in a Poser format content directory under the Figure library, indicates that you have the wrong folder selected - it should be the folder that holds Runtime folder that you select. I suspect you have the same issue in Poser, and that's why your scenes are failing to load - either the folder containing the files has been moved or you have changed the directory set-up.
  • VitachickVitachick Posts: 135
    Ugh....None of the Daz figures will open in Daz3... Daz 4.6 is another problem
    just testing to see if it works..
    I have 2 partitioned drives that I have
    H:\Daz Content\Runtime
    C:\Program Files\DAZ 3D\DAZStudio3
    C:\Program Files\DAZ 3D\My DAZ 3D Library
    Mind you C is NOT the main drive that contains windows..
    Main drive is "E"
    This problem just started as I have a lot of save characters
    in desktop folder...Never had a problem...Dunno what happened
    Any help???
    Your content folders are not defined correctly -- "DAZ People" should not appear as a DS-format content folder. In DS3, can you go to Edit > Preferences > Directories > Content Directory Manager and post screenshots fo the DS-Format content folders and Poser-Format content folders? What is the full path to "Michael 4.cr2"?
    Ok fixed both Daz3 and Daz 4.6...Yup files were messed up..Now
    with Daz 4.6 content manager is showing icons w/o thumbnail..
    Guess I will have to continue my search as to "Where are you files..
    Don't hide I will find you.."
    Thank you for your help....Not done yet but very good start..:)
