How to add distance between two clothes so they to not poke through each other?
handel_035c4ce6handel_035c4ce6 Posts: 472
edited July 2020 in New Users
How to add distance between two clothes so they to not poke through each other? I mean like a bra and a shirt for example? I vaguely remember there was an offset parameter but cannot find it in the Parameters tab.
I presume it is possible to use the "Push" modifier but want to try different possibilities if they exists and see what is working better.
Post edited by handel_035c4ce6 on
  • ParallaxCreatesParallaxCreates Posts: 468
    edited July 2020
    Go to Edit > Object > Geometry > Add Push Modifier and add that to whichever article of clothing you wish to "push" from.
    Post edited by ParallaxCreates on
  • I have an asset called "Hot work suit" or something like that. It has a bra and a shirt - and no pokes appear although I use it on non-standard char and the shirt itself is very tight; but there are onlly few points of smoothing modifier, no push modifier and the clothes are at base resolution.
    How can this be achieved?
  • fixmypcmikefixmypcmike Posts: 19,612
    Are you saying this outfit has poke-through and you want to fix it, or that this outfit doesn't and you want to know how it's done?  Is the poke-through visible in the viewport or only when rendering?
  • barbultbarbult Posts: 24,836
    Push Modifier won't show up on the clothes until you add it. Select the clothing object in the Scene pane and follow the instructions that ParallaxCreates gave you above.
  • It shows to the render until I raise the push modifier to 1.25.
    Probably I'll find some othe way to create what I need, thanks.
