Underarm/back issue with Beautiful Bends G2F?
Ankoku-jinAnkoku-jin Posts: 18
I just got the "Beautiful Bends" bundle for G2F and G2M in the Countdown sale. I'm seeing a strange distortion on the back under the arms with all of my G2F models (G2Ms appear to be OK). I've attached a test render with three different G2F models: Basic Female, Danika, and V6.
I did have Ideal Beauty for V6 installed at the same time, but during troubleshooting I uninstalled both of them before reinstalling each one by itself and testing them out. The issue only occurs when Beautiful Bends is installed, even alone. The morphs for the elbows, knees, and feet all work fine; the issue is only in this one place.
Has anyone else seen this? Thanks in advance!
976 x 533 - 62K
  • Richard HaseltineRichard Haseltine Posts: 100,841
    Is this the default G2F shape, aside from Beautiful Bends?
    edited June 2014
    Hmm, yes - I see this having just installed the update I downloaded yesterday. please make a bug report. However, despite uninstalling (and reinstalling and again uninstalling) I still have Ideal Beauty showing in Parameters so it may be there's a packaging error somewhere. Edit: but manually removing the Ideal beauty files hasn't removed the issue..
  • Ankoku-jinAnkoku-jin Posts: 18
    Will submit a bug report, thank you for checking!
  • wowiewowie Posts: 2,029
    edited June 2014
    Hi.
    There was a mixup with the installer a while back before the bundle came out. Both the update and older file versions were merged. I'm guessing this is the one you're using. I recommend uninstallling your current version (make sure the older files are deleted) and re-download the installer files. The ones I just downloaded via DIM works fine. I've also checked the /zip version and they're also fine.
    Sorry for the inconvenience.
    Edit:
    Turns out the issue is caused by something else. There's an update on the way.
    Post edited by wowie on
