Fix That pesky freebie .obj with only one material for everything
mCasualmCasual Posts: 4,607
edited July 2020 in Freebies
https://sites.google.com/site/mcasualsdazscripts9/mcjobjgrouptomtl
so you downloaded a freebie bike and there's only one material for the whole bike?
this script will create one material/surface per group name
it creates a copy of your .obj file with those changes in the same disk folder with the same filename but the suffix 'out'
960 x 960 - 477K
Post edited by mCasual on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,507
    this looks handyheart
  • mCasualmCasual Posts: 4,607
    edited July 2020
    thanks, it worked well for this bike though some parts would need to be split some more
    1080 x 1920 - 825K
    Post edited by Chohole on
    yeah I spent literally hours selecting by parts and assigning to new surface on the Riot Games cinematic models with the geometry editor
    this would have been a godsend then
  • manekiNekomanekiNeko Posts: 1,414
    edited July 2020
    thanks a lot for this very useful, very appreciated script! just made an incursion in newly discovered open3dmodels, found many interesting things - but i'll have quite a bit of work of format conversion from whatever to obj, then hopefully not much or no UV fumbling (edit: yeah... keep on dreaming...most of the UV get lost during conversion, taken the items actually had some. except fbx, but this format has other surprises), and of course the usual material panel war until they're daz-eable as props... so your script is an absolute must have! yes
    Post edited by manekiNeko on
  • nitehawk_ltdnitehawk_ltd Posts: 387
    A link to the bike?
  • HibernatusHibernatus Posts: 19
    Amazing! Thank you so much.
  • GreymomGreymom Posts: 1,117
    Wonderful!  Very, very useful.  Many thanks!
  • Jan_ScrapperJan_Scrapper Posts: 353
    Thank youi!
  • Faeryl WomynFaeryl Womyn Posts: 3,659
    I know where it saves the new obj and its name but where would I find the new uvmap or do I have to create one after using this script.
    the uv mapping if there is one in the original file will be the same in the output .obj
    if the .obj file has no UV coordinates, then you cant really apply image/textures to it and get something useful
    except ...
    if you use one of my UVmap creator scripts ...
    https://sites.google.com/site/mcasualsdazscripts3/mcjboxuv
    https://sites.google.com/site/mcasualsdazscripts4/mcjsphericaluv
    https://sites.google.com/site/mcasualsdazscripts4/mcjcylindricaluv
    https://sites.google.com/site/mcasualsdazscripts4/mcjplanaruv
    all this script does is, for each group in the original file, a material with the same name as the group is created
    if there is already more than 1 material in the initial object, this script is possibly not useful
    edited July 2020
    A link to the bike?
    i think it was this one , i was searching for the word Ducati because i wanted to make the image below
    https://sharecg.com/v/54751/related/5/3D-Model/Ducati-Bike-Melod
    i removed the bike stand by using Daz's Window/Panes (Tabs) / Tool Settings    then the Geometry Editor tool
    1080 x 1920 - 203K
    1080 x 1920 - 328K
  • FirePro9FirePro9 Posts: 456
    Great tool, thank you!
