fire on a line
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
Hi!!! I have to do a line, on the ground, done with fire... not animated, but, if possible, a convincing fire... also, I have inagoni plug in, but , if getting a single fire seems easy, doing a long line of fires is difficult! if anybody has an idea? thank you for help!!!
  • DUDUDUDU Posts: 1,945
    If you want, I can do that for you in post-prod. (targa file or other with alpha)...
  • pwiecekpwiecek Posts: 1,582
    Look at Jepe's Flamez series. They are basically textures for a flat plane that's meant to be positioned face on in a render. BUT if you took them and lined them up and were careful with angles, it might work. And there are a LOT of individual flames, so you could go a long time before you had to repeat any. If you're interested, let me know and I'll look inside and give a count.
    They could probably be combined in some way for more variety.
    I made a very fast test (animated), but here I use a picture only.
    I can make all kind of fires, with smokes too.
    You can download the scene here: http://mhdproductions.be/Carrarators/Fireline.zip
    600 x 466 - 37K
  • laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
    whowww, thank you so much for your help, and your time!!! I didn't think about an alpha job, just trying, without success, to use the fire primitives... thank you!
