Workspace size
in New Users
Sorry for another question. My workspace is 700 x 910.(as shown in screenshot) I set my render settings to 800 x 1040. How can I change the 700 x 910 to
a larger size? Hopefully this will be my last question in this forum. But while I am here, what is the highest render settings you can have? I am using the
latest version of Studio (4.12 I think)
1553 x 774 - 116K
The white border is the aspect frame. It will hold the shape of whatever render setting size you have selected. How large a full render will be depends on the size set in the Render Settings.
Thanks for the reply. In the screenshot, my render settings are 800 x 1040. I thought the aspect frame would resize to that but it stayed a 700 x 910. Why I asking this is I had a
scene where the arm was not fully showing in the aspect frame which was set at 700 x 910. When I rendered it, it did not show the missing part of the arm. I changed the render
settings to 800 x 1040 and rendered again but that part of the arm did not show again.
The numbers you see in the aspect frame are not (necessarily) the pixel size, they are the aspect ratio. 700:910 is the same ratio as 800 pixels by 1040 pixels. The white box shows which part of the viewport will appear in the final render, so if the arm is not within the box it will not show in the render.
My viewport is currently showing 3:4 - that is definitely not the pixel size! Go to "Render Settings" - "General" and you should see your aspect ratio showing there as 700:910.
As far as I can see, the maximum render size is 10,000 pixels in either direction.
The purpose of the Aspect Box is to show all which will be in the render. If for eg., the arm is outside of that box, then it will not be in the render and it does not matter how big you make the render.
