rename shaders
Torkuda
This seems like a really simple thing, but I don't see an intuitive way to do it. How do you rename textured attatched to an object in Carrara?
In the lower right corner of the Assemble Room is a box with multiple tabs
Instances : Objects : Shaders : Sounds : Clips
Select the Shader tab
A list of the current shaders in your scene appears
Select the shader that you want to change the name of
A new menu will appear in the upper right with a slot for the name
Change the name as desired
if you want to rename the actual surface too,
go i to the vertex room with it selected,
on the near bottom right check the global tab and you can rename them
