Transferring objects, but not G3/8 figures
adam_gragg
So in a strange turn of events, I discovered that the bridge (for all versions) is working perfectly fine... when it comes to transferring objects. I can get them in to the respective program, no problem! It's great. HOWEVER... while objects are transferring, Genesis 8 and 3 figures are not transferring. Anyone know why?
they objected to being transferred.?
So what have you managed to import? Older figures or just primatives maybe?
Actually, I can import pretty much any object, such as trees, props, vehicles, with little to no problem. The textures even convert just fine. But G3 or G8 figures are a no-go
What happens when you try?
Well, that's obviously not the expected result - unfortunately I don't have either of the applications you are using so I can't offer much concrete advice.
Are you a Daz employee?
No, so I don't have access to the internal machines (I did suggest they should buy a set of licenses for the forum team, but the suggestion fell on deaf ears).
How is Smart Content non-functional - completely empty or something short of that? How do you install your content?
It no longer sorts anything. For example, let's say I create a male G8 character. Normally, if I were to click on the Wardrobe section within the Smart Content tab, only G8 male wardrobe would appear. It no longer sorts like that.
Filter By Context, at the bottom-left of the pane, is checked?
