i bought a Dforce hair but it doesn't export what
i bought this hair https://www.daz3d.com/dforce-afro-styles-hair-for-genesis-8-females i need to use it in cinema 4d and clo3d but iI can't seem to get it to export I tried both obj and fbx
Maybe try the Cinema 4D section. Keep in mind that dForce hair is designed for DS and doesn't travel especially well.
Moved to Cinema 4D Discussion.
This seems to be dForce (strand-based) haiir, and the FAQ says "Strand-based hair will have difficulty transferring." https://helpdaz.zendesk.com/hc/en-us/articles/360046243772-FAQs-for-Cinema-4D-Bridge
If you export the figure as an obj, then C4D will import the deforce hair as splines.
Then select all the null objects that contain splines.
Then right click and select "Connect objects + delete" to turn all the splines ino one spline.
Now open this tutorial https://www.youtube.com/watch?v=yinvhLIuaGE&t=664s and jump to 6:36 and follow it to make the spline into dynamic hair.
It worked for me :)
I did what you recommended but i have no idea how to make it so the hair is animated, i animated it in Daz (dforce) and when i export it i get the splines and convert then to hair but the hair isn't sticking to the head...so it just floats all over the place, which is odd.
Any ideas ?
Mod Edit :- to sort out the quote
