Problem with the "trend setter" outfit
in New Users
Hi,
I have been trying to use the "trend setter" outfit on a genesis 3 female character and at first I was successful...
But for some reason the shirt and shoes part of the outfit now look like this (see attached screenshot) and I don't know why...
I tried to use the "fit" tool but it only aligned and scaled it (apparently)
I'd appreciate any advice, I'm very new to this software
862 x 719 - 116K
How did you install it?
When that happens to me, it's normally because my textures aren't installed in the correct folder. If you did a manual install, I'd check and make sure you popped everything into the right drawer. If DIM installed it I'd say, have DIM uninstall and then re-install it again. Hope that helps. And it is odd that it's not effecting the pants.
That indicates that the asset files are not being found or are corrupt. How did you install?
I tried to install it and uninstall it both through DazCentral and Daz Install Manager... Note that the pants on the screenshot is from the same outfit
I think I remmeber tryin gto use the "auto-fit" feature on a genesis 8 character (this si meant for genesis 3) before this happened. Is there any chance this has triggered this bug ?
