I dont know how to enable the script menu
in New Users
Hey, i recently downloaded the bridge to blender addon, but when i watched the video on how to transfer models, i run into a problem right away. I dont fine the script drop down bar.
I tried to google it, but i didnt come across such a thread yet. Thanks in advance.
554 x 200 - 10K
Did you "buy" (for free) and install the Daz to Blender bridge?
I installed it in the DIM, maybe there is an other way?
This forum post may help - others have had the same problem: https://www.daz3d.com/forums/discussion/comment/5857131/#Comment_5857131
I think the file they refer to is supposed to get run automatically but for some reason this isn't always happening.
Edit to add - I'm guessing you are using the current build of DS 4.12 not the Beta, but if you are using the beta there are more instructions here:
https://www.daz3d.com/forums/discussion/comment/5855011/#Comment_5855011
If DS was running when you installed the script you need to restart - the Run Once script is checked at start up.
I managed to get the scripts menu by the above mentioned forum post. Strangly after running the file, it disappeared. Maybe it was supposed to be like that im not sure. Daz popped up a msgs saying the file doesnt exist anymore, but i could see the scripts menu now, and i was able to export a model, and load it in blender.
Thanks for the help guys.
Yes, the runonce script is supposed to delete itself after running, so it only runs once.
Actually DS will, barring issues, delete the script - otherwise one that failed to complete the deletion step would keep running every time DS started.
nice
