Chainmail for Daz Genesis Geometry Shell (DS 4.6)
You can download it here: http://www.sharecg.com/v/76553/browse/21/DAZ-Studio/Chainmail-for-Daz-Genesis-Geometry-Shell-DS-4.6#
This download was created with two other resources:
Chainmail Seamless Tile And Maps Merchant Resource by fictionalbookshelf
http://renderosity.com/mod/freestuff/?item_id=73125
Genesis 1 Single UV Maps and Utility Paint Morph by Ghastly
http://www.sharecg.com/v/70652/gallery/21/DAZ-Studio/Genesis-1-Single-UV-Maps-and-Utility-Paint-Morph
Both of these items are included in this download.
Steps to use:
Step one: Load Genesis
Step two: Select Genesis
Step three: Click Create -> Geometry Shell and name it
Step four: Select the Geometry Shell
Step five: Apply one of the presets.
Step six: Change the UV to one of the Single UV options IMPORTANT!!!!!!!
You can change the opacity of the parts you want to show and the parts you don't.
The texture has been applied to the entire geoshell, only the undesirable parts have their opacity turned down to zero.
If you want the chains smaller or bigger, change the Vertical and horizontal tiling values on all the surfaces.
Thanks to Ghastly UVs, you can use nearly any texture to create a bodysuit. Before, it would show seams where the arms and legs connect to the torso.
Known Problems:
YOu usually can't see someone's belly button through chainmail.
Finger and Toenails don't work well because they are their own surfaces and thus you get really tiny chains on those surfaces.
The neck doesn't look too good so it's opacity is turned off.
Unrestricted use as long as you don't repackage it and sell it.
Thank You, that looks good :)
Very clever indeed! Never thought of that.
Very nice idea - and it works! Thank you!
