How do I constrain a middle po…
Daz 3D Forums > Software > Hexagon Discussion>How do I constrain a middle po…
How do I constrain a middle point in a three point line?
sajiky
Can anyone tell me how to constraine a middle point to a line between two others? Picture a v shape, I want to take the bottom point and move it exactly between the other two. Gotta be a way right?
Thanks.
Have 2 lines selected and choose the auto-tessellation option which makes then an evenly spaced line between those 2 lines. Picture an H.
Then select the unwanted lines and backspace on the keyboard ... do not remove vertices. There should be remaining an evenly placed dot on the one line.
Create a line.
Select line.
Click Line Tesselation.
Done.
Simples.
Create a line.
Click Insert Points.
Hold down SHIFT.
Click on line.
Done.
Simples.
There's usually more than one way to make something you need. I'd use a cube, tesselate1, then select one of those edges, copy/paste generates the 3 point line. delete cube.
