doubt about adding models and addons
dmvitti2dmvitti2 Posts: 0
edited August 2020 in New Users
edit1:
I really need to add the genitals in the characters,
but I'm not getting it with any addon and the daz store doesn't offer that kind of thing to sell
I tried to search in several places and I don't find much and when I find an addon for that it doesn't work for some reason I'm almost giving up ;-; and this doesn’t apply to just this addon, various poses and models for some reason don’t appear too can someone help me?
note: I used google translate so it may contain spelling errors.
Post edited by dmvitti2 on
  • The Daz Anatomical Elements for each sex and generation are included in most Character Name Pro Bundle sets, other characters will have materials to make them match the rest of the figure but not the mdoels themselves. Some other stores do have their own, stand-alone versions but you need to be careful that you are buying a full item and not a modification for the Daz or other anatomical elements.
    really what I need and put the genitals in the characters.
  • ChezjuanChezjuan Posts: 522
    edited August 2020
    As Richard said, you need to purchase one DAZ Pro bundle for each gender in the DAZ3d store in order to get the anatomical elements. I suggest Michael 8 and Victoria 8 as they are adult characters who come with the add on.
    https://www.daz3d.com/victoria-8-pro-bundle
    https://www.daz3d.com/michael-8-pro-bundle
    Once you purchase these, the elements will be available for most other adult characters of the same generation.
    This is the only way to get them through the DAZ store.
    ETA: I am assuming that you are using Genesis 8 as it is installed by default and is the latest generation. If you are using an earlier generation, such as Genesis 3 or Genesis 2, you need to purchase one male and one female adult pro bundle in that generation.
    Post edited by Chezjuan on
  • SimonJMSimonJM Posts: 5,997
    Alternatives exist in other stores, particlarly Renderotica, and do not require the pro version of a figure
    I understand you guys wanted to talk,
    However, if I buy these packages, will I have the genitals only in those packages or can I use them on other characters too?
    or be used in another structure than in Victoria.
  • Richard HaseltineRichard Haseltine Posts: 102,701
    edited August 2020
    The anatomical elements work on all adult characters using the same base figure - e.g. the Genesis 8 Female set works on the Victoria 8, Stephanie 8, Rory for Genesis 8 female(s) and so on characters - as long as they include materials for the anatomical elements.
  • The anatomical elements work on all adult characters using the same base figure - e.g. the Genesis 8 Female set works on the Victoria 8, Stephanie 8, Rory for Genesis 8 female(s) and so on characters - as long as they include materials for the anatomical elements.
    it must be due to the lack of these "pro" models, so the plugin I bought should not be working either.
    vlw even to both for the help: D
