No Pose Controls on Import [SOLVED]
shutascomputas
Hey all,
No matter what character I bring in to Cinema 4D via bridge, there are no pose morph controls. What am I missing? Do I need to enable this some where?
Thank you!
Post edited by shutascomputas on
I think you can do it easly, using morph on Cinema 4D or from. Im doing my own morphs movement in C4D.
I can't quite get the finer controls/finesse that pose morphs seem to offer. I've been moving the face rig with axis controls. I would much prefer the pose morph tags. Thanks for your input!
The face morphs you move if you export them with FBX. Except for movement (axis). If you are referring to expression morphs, there is a way to do this. Would these be?
I was referring to the pose morph controls after importing with Daz to Cinema 4D bridge. The tutorial videos I've seen have the models with pose morph tags after importing using bridge.
looks like u talk about RIG, that controls...IK called. have the option to set that but morph, i dont know if work right now, in this version of the bridge. Looks we have some insues about.
Not the IK rig, but the pose morph tags. See the link above, this is what I'm looking for. My imports do not have any pose morph tags.
Okay, I found the solution. If you find yourself unable to see any pose morph tags on import from Daz Bridge, go to your C4D preferences -> Import/Export -> FBX Import -> be sure under animation "Poses" is checked on.
I dont know why this thing says "solved". I see no solution here. I am having the same issue. C4D bridge imported all of the morphs with the figures in DAZ 4.12, and now, in 4.14, there are no morphs when imported into C4D with the bridge. I put in a support ticket, and the response I git was that they "couldn't help me".. it's ridiculous.
Marked as solved I guess because the post above yours has the solution for the OP; but maybe they might not have been using 4.14?
Either way, I got a response back from Support as well basically saying they don't offer tech support for the Bridges right now, so any problems we have with them are something we have to sort out ourselves. Not really possible when it comes to updating their bridge to work with R23 sadly :/
So..... I I can't really use the critters and props I own here. (Yes, I've tried DAE/FBX exports and they kinda work, but I have to do re-rigging on the ones that don't import as a unholy broken mess and none of them export with morphs or etc no matter what I try checking in Export.)
In the meantime if I want to use any DAZ stuff I have to do so in R13 since I have InterPoser Pro there. I can't use any of the DUFF-exclusive stuff though, and won't be able to until the C4D Bridge finally works with R23 :/
same problem, no pose morph tags after I press the IK rig.
anyone get a fix?
same problem, thought i was crazy :( any solutions yet?
Same here, I foolishly upgraded to 4.14 because I thought I could make use of the IK rig exporter to c4d in the video above! But now Ive got zero morph controls on all the exports, which is way harder to set up then an IK rig. :( woud like to roll back but I cant find my zip...
Same problem! No Pose Morph tag on import. Any solutions already?
No luck, this is not solved with studio 4.15...
Any workaround ?
Having the same problem in S24, unfortunately no Pose Morph tags, any solution?
