Outfit problem
in New Users
Hi.
I installed this outfit: https://www.daz3d.com/sugar-for-v4-outfit
but when I try to equip it on V4 nothing happens. Can anyone help me?
Which files are you trying to load? Sounds to me you may be using a material file rather than the actual items.
I'm assuming that's the outfit but when I click to apply it on V4 nothing shows up. I have no problem with other V4 outfits , just this one.
That thumbnail definitely looks like a material pose from a texture add-on. You need to load the actual clothes, from the figures library.
Where can I find them? I searched everywhere but I can only find that. And this is all that I have in that location
Dusk folder is missing.
They should be in Poser Formats - Figures - SugarV4 - are you definitely looking under Poser Formats in Content Library?
ETA: How did you install? I don't see why anything for V4 would be installed into a "Dusk" folder.
"Dusk" is not the folder for the product, that's the name of an add-on (this one I suppose).
The folder to load the base outfit is "SugarV4" in Figures library. Once you've loaded the outfit you can apply the Dusk textures to it.
Hello my outfit does not appear there. I have Sugar for V4 - Outfit This is the base product?
Yes, this is the base product. I reinstalled it in a test directory to take that screenshot so that it is in the default location, so it should definitely be there.
How can I install it in a test directory?
I installed it manually: I unziped the product zip to a temp folder on my PC, then moved the runtime directory from the temp folder into a test folder listed as a content drectory in DS preferences.
I installed the full bundle again and now it's working perfectly.
