-- Error : Unknown property: 'name' in undefined
When I try to import using the daztomax bridge I get the following error.
How do I fix this?
I tried reinstalling the daztomax plugin, reinstalling max and Daz but none worked.
Thank you.
985 x 742 - 155K
Post edited by rashigaw on
Please attach your image to the post, it's not showing (for me) except by editing the post (which others can't do).
Hi Richard,
Thank you for your reply. Please check the updated post.
Best Regards,
Rashiga
What was being sent across the bridge? Was it a figure?
yes, it's a standard genesis 8 character.
Richard,
The following code is the code form MAXscript listener.
"DazToMax.fbx"
"--------------------------------tiling values:---------------------------"
1
1
0
0
"EyeMoisture:1"
1
1
0
0
"Eyelashes:0"
$PolyMesh:Genesis8FemaleEyelashes.Shape @ [0.000000,0.000000,0.000000]
$Dummy:Genesis8Female @ [0.000000,0.000000,0.000000]
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\DazToMax\DazToMax.ms; position: 80950; line: 2870
-- MAXScript Rollout Handler Exception:
-- Unknown property: "name" in undefined
-- MAXScript callstack:
-- thread data: threadID:104060
-- [stack level: 0]
-- In li loop; filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\DazToMax\DazToMax.ms; position: 80894; line: 2866
-- Parameters:
-- li: ""
-- Locals:
-- obj: undefined
-- li: ""
-- Externals:
-- owner: undefined
-- selectedObject: Free:selectedObject : undefined
-- [stack level: 1]
-- called from btnAutoImport.pressed(); filename: C:\Program Files\Autodesk\3ds Max 2020\scripts\DazToMax\DazToMax.ms; position: 80951; line: 2870
-- member of: Rollout:rConverter
-- Locals:
-- prefix1: "QR_CAT_Base Human"
-- listmain: #("", "Pelvis", "LPlatform", "RPlatform")
-- listSpine: undefined
-- h: undefined
-- b: "rThighTwist"
-- t1: undefined
-- pelvisPos: [0,-1.76829,107.746]
-- delta: 0.5
-- t: undefined
-- n: 40
-- auto: undefined
-- lrPos: undefined
-- t2: undefined
-- dir: [0,0,208.933]
-- spinePos: [0,-1.425,113.074]
-- p4: undefined
-- temp: undefined
-- d2mXmlDoc: dotNetObject:System.Xml.XmlDocument
-- rNode: undefined
-- ribcagePos: [0,-0.395122,129.056]
-- neckPos: undefined
-- xmlFile: "objguides_Genesis3Female.xml"
-- j: 2
-- data: dotNetObject:System.Xml.XPathNodeList
-- isFBX: true
-- selObj: undefined
-- obj: undefined
-- newPrefix: undefined
-- p2: undefined
-- CATRoot: undefined
-- filename: "DazToMax.fbx"
-- p3: undefined
-- arr: #(#("Human", "0", "QR_CAT_Base Human", "QR_Bip002", 2.0, "color 0 255 0", "Genesis3Male", "QR_CAT2b.max"), #("Pelvis", "1", "Pelvis", "Pelvis", 5.0, "color 255 0 255", "pelvis", "pelvis"), #("Spine01", "3", "Spine1", "Spine", 30.0, "color 255 0 255", "abdomenLower", "abdomenLower"), #("Spine02", "3", "Spine2", "Spine1", 30.0, "color 255 0 255", "abdomenUpper", "abdomenUpper"), #("Spine03", "3", "Spine3", "Spine2", 30.0, "color 255 0 255", "chestLower", "chestLower"), #("Spine04", "3", "Spine4", "Spine3", 30.0, "color 255 0 255", "chestUpper", "chestUpper"), #("Ribcage", "1", "Ribcage", "Neck", 20.0, "color 255 0 255", "neckLower", ""), #("Neck", "1", "Neck", "Neck", 8.0, "color 255 0 255", "neckLower", "neckLower"), #("Head", "1", "Head", "Head", 8.0, "color 255 0 255", "head", "head"), #("Head1", "1", "___", "HeadNub", 3.0, "color 255 255 0", "", ""), #("LPFoot", "0", "LPlatform", "L Foot", 2.0, "color 0 255 0", "LFoot", ""), #("LLegUp", "4", "LThigh", "L Thigh", 2.0, "color 87 225 87", "LThighBend", "LThighBend"), #("LLeg", "4", "LCalf", "L Calf", 2.0, "color 87 225 87", "LShin", "LShin"), #("LFoot", "4", "LFoot", "L Foot", 2.0, "color 87 225 87", "LFoot", "LFoot"), #("LToe", "4", "LToe1", "L Toe0", 0.5, "color 87 225 87", "LToe", "lToe,lBigToe,lSmallToe1,lSmallToe2,lSmallToe3,lSmallToe4"), #("LToe1", "5", "___", "L Toe0Nub", 0.5, "color 255 225 0", "LSmallToe2_2", ""), #("LShoulder", "2", "LCollarbone", "L Clavicle", 4.0, "color 87 225 87", "LCollar", "LCollar"), #("LArm", "4", "LUpperArm", "L UpperArm", 2.0, "color 87 225 87", "LShldrBend", "LShldrBend"), #("LForeArm", "4", "LForeArm", "L Forearm", 2.0, "color 87 225 87", "LForearmBend", "LForearmBend"), #("LForeArm1", "4", "LForeArm1", "L Forearm1", 2.0, "color 87 225 87", "LForearmTwist", "LForearmTwist"), ...)
-- i: 9
-- headPos: [0,1.80195,163.15]
-- selectedObject: undefined
-- newarr: undefined
-- w: undefined
-- p1: undefined
-- list3: #("Thumb", "Index", "Middle", "Ring", "Pinky")
-- lsPos: undefined
-- listDummy: #($Dummy:Genesis8Female @ [0.000000,0.000000,0.000000], $Dummy:hip @ [0.000000,-1.702816,105.885704], $Dummy:pelvis @ [0.000000,-1.768290,107.746254], $Dummy:abdomenLower @ [0.000000,-0.276216,107.730858], $Dummy:lThighBend @ [7.978765,-0.305637,97.213058], $Dummy:rThighBend @ [-7.982243,-0.288892,97.204948], $Dummy:abdomenUpper @ [0.000000,-1.489601,115.850471], $Dummy:lThighTwist @ [10.689296,0.054019,76.328041], $Dummy:rThighTwist @ [-10.717156,0.078259,76.326706], $Dummy:chestLower @ [0.000000,-1.118514,123.669525], $Dummy:lShin @ [14.259117,1.732501,51.111412], $Dummy:rShin @ [-14.297480,1.764110,51.133881], $Dummy:chestUpper @ [0.000000,2.358694,136.653061], $Dummy:lPectoral @ [3.077013,7.279979,132.480453], $Dummy:rPectoral @ [-3.078894,7.279630,132.479950], $Dummy:lFoot @ [20.476238,4.544551,8.853523], $Dummy:rFoot @ [-20.478298,4.541809,8.855305], $Dummy:lCollar @ [3.435369,4.041263,147.502853], $Dummy:rCollar @ [-3.434905,4.042247,147.507202], $Dummy:neckLower @ [0.000000,3.911015,154.873322], ...)
-- prefix: undefined
-- xmlDoc: dotNetObject:System.Xml.XmlDocument
-- thumbMode: 2
-- Externals:
-- rPBar: Global:rPBar : Rollout:rPBar
-- syncCATXML: Global:syncCATXML : syncCATXML()
-- importDAEFiles: importDAEFiles()
-- chkMorph: RolloutControl:chkMorph in rollout:rConverter : CheckBoxControl:chkMorph
-- name2Index: Global:name2Index : name2Index()
-- setCATposition: Global:setCATposition : setCATposition()
-- autoRename: autoRename()
-- file_xml: Global:file_xml : "C:\TEMP3D\DazToMax.xml"
-- defineRootLocator: Global:defineRootLocator : defineRootLocator()
-- newBone: Global:newBone : newBone()
-- owner: Rollout:rConverter
-- backgroundColor: SystemGlobal:backgroundColor : (color 19 19 19)
-- listXML: Global:listXML : #(#("rThighTwist,rThighBend,rShin,chestLower,abdomenUpper", "objguides_Genesis3Female.xml"), #("abdomen,abdomen2,chest", "objguides_Genesis2Male.xml"), #("SENTINEL_177853,abdomen", "objguides_SENTINEL_177853.xml"))
-- loadStandardOrPhysicalMaterial: loadStandardOrPhysicalMaterial()
-- morphRenamer: Global:morphRenamer : morphRenamer()
-- importFBXFiles: importFBXFiles()
-- cbShowReminder: RolloutControl:cbShowReminder in rollout:rConverter : CheckBoxControl:cbShowReminder
-- selectHierachy: Global:selectHierachy : selectHierachy()
-- n2n: Global:n2n : n2n()
-- wireConnect: wireConnect()
-- rConverter: Rollout:rConverter
-- d2mConfigpath: Global:d2mConfigpath : "C:\Program Files\Autodesk\3ds Max 2020\scripts\DazToMax\"
-- [stack level: 2]
-- called from top-level
i have same problem
I have the same problem, is there a solution?
Have you already found a solution to this problem?
Have same problem for couple of weeks. It seems that FBX has all the maps alongside with model, but upon importing in max it creates folder only with one or two maps (for lashes in my case) and sends same error.
I already tried removing assets that i have installed since the last successful export from Daz>Max using bridge but it still sends same error. Tried exporting base genesis model to max and still the same problem. :<
