mcjTornare - DS 1,2,3,4+ Script to turn something ( usually an arm ) around an arbitrary axis, quick
before resuming my resuming work on mcjTeleblender 3
a quick script to animate turning motions
https://sites.google.com/site/mcasualsdazscripts4/mcjtornare
rotating around an axis that is not one of the three ( x y z ) axis
similar to mcjExoRotator http://www.daz3d.com/forums/discussion/35826/
Fig 3
well actually this was made mostly using
-mcjAutoLimb2014
-mcjHoldOn
-mcjMakeTarget
-mcjParent
-mcjKeepOrient
362 x 512 - 276K
362 x 512 - 529K
212 x 300 - 400K
1280 x 720 - 266K
1414 x 2000 - 1M
Post edited by mCasual on
Now, this will be neat! I'll be watching and waiting.
since there's already mcjExoRotator for complex animation tricks
i'll stick with my original intent which is a simple script
for cases where you just want to select 2 nodes, click a button and bam
the rotation is done - well you must also specify the angle in degrees
1 - select a target ( the tip of a screwdriver parented to an arm )
2 - select a turning node ( the shoulder joint of that arm )
3 - specify a spin angle ( 45 degrees )
4 - Specify the keyframes to process ( current frame only )
4 - click the 'do it button'
done !
fig 2 - a spin angle of 30 degrees was added to an exosting 15 frames animation in 1 click !
Fig 3 - Testing in DS 4.6 and adding fearures
fig 4 - the official logos ! collect all 2
fig 5 - the test in DS 2.3 was interesting it shows cumulative effect of the rotation when you start with something that is not yet keyframed
* * Ready ! * * Ready ! * * Ready ! * * Ready ! * * Ready ! * *
New Improved ! and there's a Movie ! ( 1 minute and a half, lets say a short feature ) for mcjTornare
Exciting action-packed ! with custom TTS-lipsync
https://www.youtube.com/watch?v=_wHzuOrKBfg
The new version of the script is at
