Octane Render with Carrara?
Hey all
About to upgrade to a new computer (PC Win 10)
I do mostly animations. Will I get a big boost in render speed using Octane with an Nvida 2060 GPU?
That card has 6 gig of memory when rendering sequenced PNG does it "dump" ram for each frame?
If I load models I have created with standard Carrara shaders, will then look OK if I choose octane render?
I like the look I get with stock carrara I am mainly looking for render speed. Any warnings?
I'm using for my youtube channel so computer time is a big deal. Is it only one computer?
https://www.youtube.com/channel/UCP6P9O1FjLeQ7ztc7ao4xOw
Thanks You
Brad
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,352
    edited October 2020
    procedurals won't work but simpler mix, add, multiply etc operators will, noise etc won't
    I use inagoni baker to create new textures but if you don't have it, it's a bit difficult to buy it now as you need to contact Julian somehow
    https://www.daz3d.com/forums/discussion/320486/carrara-7and-8-win-mac-inagoni-download
    otherwise render out texture tiles on a plane (Carrara render) using the isometric camera and 100% ambient no lights.
    Carrara trees can quickly use up all your VRAM too
  • 3drendero3drendero Posts: 2,027
    You should get a big boost. Get the trial, the rental at 20$€£ should also be able to cancel after 1 month, check the TOS or ask their support.
