plant obj import is not displayed properly
machelmanmachelman Posts: 0
I have plants brought from the Daz 3d shop for Vue and Daz 3d. I then tried, as these plants can not be in Daz 3d, import, export these plants with VUE Infinite PLE 2014 as obj file. Unfortunately, this is Bryce7 per obj files dar. wrong Can anyone help me? entschuldit my bad English, Google translator was. Thank you for the quick help.
Greeting Frank
1194 x 563 - 37K
    What product is that you have bought?
    Do you have a transmap to apply to the leaves
  • HoroHoro Posts: 10,638
    @machelman - Welcome to these forums. Keine Probleme mit der Sprache. It appears that you need to set transparency. Leves are often just 2D faces and to get the form, transparency must be set.
    Image 1 shows an XFrog tree imported as OBJ into Bryce. The leafes are rectangular sheets.
    Image 2 shows how you have to set transparency. Select the foliage and go into the Materials Lab by clicking on the [M]. Check the settings I have identified with red arrows.
    Image 3 shows the same tree with these settings.
    600 x 450 - 72K
    637 x 503 - 65K
    600 x 450 - 38K
