Free Geghard column prop
SlimerJSpudSlimerJSpud Posts: 1,453
edited December 1969 in Freebies
I went back and rebuilt a column prop I created for a Bruuna render. It's based on a photo I took in a place called Geghard in Armenia. Talk about spooky! Well, what do you expect? The place is 800 years old! See: http://en.wikipedia.org/wiki/Geghard
The freebie has a pp2 file, and various MAT files compatible with Poser, and DS3+ The prop will load up with 5 parts, which may be selected and turned off for various effects. The .dsa MAT files will restore the bump and displacement settings I used to get a rough surface. Thanks to mCasual Jacques for his MCJLathe script. Very easy to use. I used it to make the "gumdrop" shape at the top and bottom. If there are any problems, let me know so I can fix it.
The Readme text is also on the ShareCG page:
http://www.sharecg.com/v/76912/browse/11/Poser/Geghard-Column
1024 x 768 - 374K
