Scripts Delete Keyframe Figure and Lock parts body for DS3 and DS4 (update V1.3)
Scripts for Daz Studio 3.1 and 4.x
ACDZ_DeleteKeyFigure.dsa .- Delete Keyframe actual for figure
ACDZ_DeleteKeyFigureDialog.dsa .- Delete Range of Keyframes for figure or nodes selected
ACDZ_LockPartBody.dsa .- Lock/Unlocks or nodes selection for parts bodys
Changes: Add selection nodes for parts bodys
fix selection all for LockiPartBody
Add selection nodes for "delete range Keyframes figures"
http://www.sharecg.com/v/76963/view/21/DAZ-Studio/scripts-for-Delete-keyframe-and-Locks-V1.3
Warning:
Problems with morphs DaZ Studio for 4.X
Based in scripts mCasual
// DAZ Studio version 3.1 filetype DAZ Script
//Delete KeyFrame a Figure of Frame Actual
//Version 1.3
var tick = Scene.getTimeStep();
FrameActual=Scene.getFrame()
var TimeRange=DzTimeRange(FrameActual*tick,FrameActual*tick)
setBusyCursor();
beginUndo();
Procesar()
acceptUndo("DeleteKeyFrameActualFigure");
clearBusyCursor();
function Procesar()
nodeselection=Scene.getPrimarySelection();
if (nodeselection)
Skeleto=nodeselection.getSkeleton()
if (Skeleto)
//Delete KeyFrame for root Skeleto
DelKeyNodesProperties(Skeleto)
//Delete KeyFrame for All Bones
var bones = Skeleto.getAllBones();
for( var i = 0 ; i < bones.length ; i++ )
DelKeyNodesProperties( bones[ i ] );
else
DelKeyNodesProperties(nodeselection)
for( var i = 0 ; i < nodeselection.getNumNodeChildren() ; i++ )
DelKeyNodesProperties(nodeselection.getNodeChild(i))
else
MessageBox.information("Selection a Figure" ,"Information","Accept")
//////////Functions
//Transformation and Parameters for Nodes and Bones
function DelKeyNodesProperties( Node )
var NumProperties = Node.getNumProperties()
for( var i = 0 ; i < NumProperties ; i++ )
DeleteKeyProperty( Node, i );
function DeleteKeyProperty(Node,item)
Node.getProperty(item).deleteKeys(TimeRange);
406 x 394 - 64K
438 x 579 - 104K
Post edited by ajd_at_072df9a27d on
Looks promising...
Could you please give an example of usage, and under what normal conditions one would need to use this?
solutions to:
How to remove animation from scene?
http://www.daz3d.com/forums/discussion/6161/
Moving Key frames
http://www.daz3d.com/forums/discussion/608/
Usage:
For animators
Situation:
Move pose figure of frame 30 to 40
Move keyFrame Figure:
1.- "Memorize current Figure pose" frame 30
2.- Run Script ACDZ_DeleteKeyFigure.dsa (Shorcut)
3.- go frame 40 and "Restore current Figure pose "
in DS3, i get access to bone morphs using something like
in DS4.5 only the skeleton has an object,
if i remember correctly the names of the morph channels in DS 4.5
lets you know which bone is affected by each morph
Thanks casual by info.
And thanks by your scripts
I used this script but it didn't work when I used Universal tool and move the hand.
I want to make the push-up animation but I can't fix the hands on the ground, it always move a little bit between 2 actions: up and down.
Plz show me how to do this animation?
Demo the animation I want to do: https://youtu.be/5eSM88TFzAs
Thanks a lot!
if you learn and use the two following scripts, you can get very very solid animations like that
- mcjAutoLimb2015 - the whole legs and arms animation for the given hand/feet positions
https://sites.google.com/site/mcasualsdazscripts6/mcjautolimb2015
- mcjKeepOrient - the orientation of William's hands and feet
https://sites.google.com/site/mcasualsdazscripts/mcjkeeporient
for this animation i also used
- mcjHoldOn ( Gabrielle's feet orientation )
- mcjParent ( to make Gabrielle's feet targets follow William's hips )
- mcjCycleFilter yo get good looping on Gabrielle's arm movements )
"snapping leg" problem can be avoided by setting the knee limits to forbid negative bend angles -
and by making sure the feet targets are never physically out of reach
Other way with "Tool Active Pose" (EASY).
- Select nodes foots, hands.
- Toggle Pins.
- Select Chest - Move Up - down (Tool Active Pose).
This week, DAZ Studio up Tutorial.
With universal Tool (IK)
- Pin Translation/Rotation.
- Select Chest - Move Up - down.
"Tool Active Pose" is good for posing and i should use it more often!
for animations where you want feet or hands to not move a millimeter
for dozens of frames, or for an animations where hands/feet must stay "glued" to something or someone else
( ex: bike pedaling ) then mcjAutoLimb is still it i think
active pose only uses translations as far as i know
so it creates morphs where you do not want them
sorry to say but animating with this when you have to move the hip is not possible with out trembling feet or hands
or did this tool get an update ?
if the author of this videos creates a decent walking animation with active pose i would stand corrected
but it wont happen
mjcautolimb 2015 in combination with keeporient is best we have at the moment
edit2:
amy is having fun i see
where can i get an animatable bike like that ?
example of mcasuals scripts here with modified push up animation from anymatter
starring also the nice Stanley from mythcon
turn your speakers loud and watch fullscreen
renders are just opengl for quickness
V4 bends bad at the wrists
https://vimeo.com/160240622
i'll probably post the E.T. BMX this summer when i resume bullet ( or that nvidia physics sdk) bike jumps
Ive got to try this :)
Yup thats what I used for one of the scenes in this animation it worked out pretty good.
https://www.youtube.com/watch?v=q4KlH5Mz2t4
hi Ivy
lots of work in your video
i know this
but how do i embed a video from vimeo here ?
I hope this helps follow below.
PS: I always add a link as well. because some people may have some virus scanners and other security features that might prevent them from viewing embed videos in their browsers
thank you very much Ivy
