dForce clothing, how to save shape?
After much tweaking I have got a dForce dress into the exact shape I want. However, there is poke through underneath on the knee (and I can't make the relevant bit of the leg invisisble because some of it is showing). Mesh grabber does not help, the dress is so stretched anyway that it has to come up a long way and then it looks wrong. Clothing helper expands the dress segment too much too.
What I want to to do is to set the dress like a piece of concrete and then I can use mesh grabber to change the shape of the knee. That seems like the obvious solution.
Is there a way to do this? That dress shape is just fine. The figure pose is just fine. Don't need to change much. Just need the dress to stay exactly as it is while I mess with what is underneath it.
..and that's the bit I'm stuck on !
For a still image you could use Edit>Figure>Rigging>Convert Figure to Prop, with the dress selected.
Thank you, will try that
