Load a poser preset by script
BubbsiBubbsi Posts: 6
Hello Guys,
I´ve once more a question =).
So I want to load a poser preset for a genesis2 model. My Problem is if the correct node isn´t selected in the scene I can´t load the poser, so the preset will only load for an other object :/.
I researched the Scene class documentation but I can´t find the right function to select an individual node.
Can anyone help me, plz?
David.
Post edited by Bubbsi on
    Remember that some Poser files at least will not work on Genesis 2 - they require conversion to .duf files first. Or do you mean a native pose preset, not a Poser file?
    If you know the label of your target item you can use Scene.findNodeByLabel( label ) and then node.select( true ) to make it selected (you may also want to make sure nothing else is selected)
    var item = Scene.findNodeByLabel( "cube" );
    if ( item ) {
     item.select( true );
    you can also use Scene.findNode( name ) to search by name.
  • BubbsiBubbsi Posts: 6
    It´s my own poser preset so it works =).
    This was what I searched for, thank you!
    But now there are two Items selected. I tried to Clear my selection with action = getAction(166) (166 number for "Clear Selection") and action.trigger(). the script works, but nothing happens :P.
  • rbtwhizrbtwhiz Posts: 2,273
    edited November 2015
    The index of an action can/will change as new functionality is added, be it in the core or through a plugin, so you don't want to use an index to find an action. The recommended approach is to use the classname of the action like I do in this sample.
    You can find the classname of an action using this sample.
    You can also directly deselect all nodes, and then select the desired node, like so...
    // Declare working variablesvar sSkeletonLabel = "Genesis 2 Female";var sBoneName = "abdomen2";var oNode = null;// Get all of the selected nodesvar aNodes = Scene.getSelectedNodeList();// Iterate over the nodesfor( var i = 0; i < aNodes.length; i += 1 ){ // Get the 'current' node oNode = aNodes[ i ]; // Deselect it oNode.select( false );}// Find the desired skeletonoNode = Scene.findNodeByLabel( sSkeletonLabel );// If the node was found and its a skeletonif( oNode && oNode.inherits( "DzSkeleton" ) ){ // Find the desired bone of the skeleton oNode = oNode.findNodeChild( sBoneName, true ); // If the node was found and its a bone if( oNode && oNode.inherits( "DzBone" ) ){  // Select it  oNode.select( true ); }}
    -Rob
