FREE: DP Michael 6 Modern Cut Dynamic Hair
ringo monfortringo monfort Posts: 945
Yes, Free Dynamic Hair for the Carrara Community!.
This can be found at the Carrara Cafe Freepository Forum.
http://carraracafe.com/forum-3/?cid=25&show=1447
DP Michal 6 Modern Cut Dynamic Hair is perfect for when you want to take Genesis 2 males Carrara render to the Next level! 12 beautiful hair colors are also included to give you realistic hair renders.
1 Hairstyle (.CAR)
Style 1, 6 Dynamic Hair Shaders(.CBR)
Style 2, 6 Dynamic Hair Shaders(.CBR)
Free to the community
1000 x 1300 - 595K
  • DiomedeDiomede Posts: 15,210
    Very cool - thank you
    Nice one Ringo! Dang it, now you're making me have to go get into Genesis2 and Michael6 :)
  • ringo monfortringo monfort Posts: 945
    Michael 6 look great in Carrara 8.5 Pro. Have fun using the dynamic hair and let me if it downloads fine.
  • DartanbeckDartanbeck Posts: 21,675
    Whoa! Cool!
    Thank you, Mr. Monfort! You totally Rock!!!
  • HeadwaxHeadwax Posts: 10,026
    Thanks very much Ringo, that's very kind! Cheers !
    edited August 2014
    here are additions sample images of the dynamic hari
    1000 x 1300 - 604K
    1000 x 1300 - 480K
    1000 x 1300 - 288K
    Post edited by ringo monfort on
    Now I would love to see some renders done by the community. :)
    Thanks for posting those Ringo. I can't use them yet, as I still use C7.2 Pro, but that doesn't mean I can't appreciate your great generosity.
  • DUDUDUDU Posts: 1,945
    You can use it if it's not conformed to the character.
    There will be some modifications of the shape but that should work.
    I don't have Genesis but I downloaded the file for a try, thanks a lot Ringo !
    Is it on a hair cap or is it "grown" on the figure's geometry? If it's a hair cap then I can use it, if it's on the figure's geometry, then I cannot.
    EP, you are right...
    That don't work in C8, may be in C8.5 ?
    They will only work on a Genesis 2 figure (M6), so C8.5 is the only version it will work with because that is the geometry the hair system uses to grow the hair.
    Dynamic hair, if it is on a hair cap could probably be forced into an earlier version of Carrara, as it is basically a prop with no rigging, and no weighting. The hair would "grow" on the scull cap.
    Ringo's hair is probably "growing" on a Genesis 2 figure, and so it needs the same underlying geometry to grow. A V4 or an A3 or a M4 all have different geometries. You could grow hair on a V4 and use it on an A4 or Girl 4, as it is the same mesh and same number of polygons. They're just morphed differently. You could not grow a hair made with a V4 on an A3 because the the mesh is so different.
    you are right, this one is grown on the genesis 2 figure. DAZ 3D has only provided a haircap for Genesis 2 females and I have used it for some of the latest dynamic hairs that I have done. I hope to have a male haircap in the future.
    Regards
