G8F Pose Transfer to V4/A4
richardandtracyrichardandtracy Posts: 5,848
edited November 2020 in Freebies
May I present another pose transfer script. This time for G8F poses to be transferred to V4/A4.
To operate, load G8F and apply the desired pose. Then load Victoria 4 or Aiko 4, and run the script. Once more you'll need to identify V4's/A4's hip in one node selection combo box, and G8F's hip in the other. Then press the 'ACCEPT' button, and the script will run. There will probably be a need to tweak the pose afterwards, but it's likely that it won't be much more than when you apply a G8F base pose to a G8F character.
Please be aware that V4/A4 do not react well to some G8F poses, the 4 generation difference between the two figures can't really be avoided on occasions.
So, now some images. First, V4 matching G8F's base pose having originally been in her own zero pose:
Now a before and after image of a pose being applied to V4. In order to get this to work, I had to turn the V4 rotation limits off, otherwise V4 got nowhere near the G8F pose - if the pose matching is awful, you may have to do the same.
I hope this will be of some use to a at least a couple of people.
Regards,
Richard.
zip
zip
G8FPoseTransferToV4.zip
347K
923 x 895 - 405K
923 x 895 - 453K
923 x 895 - 450K
  • jedijuddjedijudd Posts: 606
    Thank you
  • Oh thank you thank you. I look forward to trying all these scripts out.
  • Must admit I have been surprised at the interest in these scripts. Always thought generation 3 was nearly dead and buried, while generation 4 was being kept on life support by a few dedicated users, but after the numbers of comments & downloads here and Renderosity, I find I've quite underestimated the numbers of people still interested in them. Amazed.
    Regards,
    Richard.
  • Catherine3678abCatherine3678ab Posts: 8,383
    To be able to match the poses between figures as close as possible for the default loads of all the figures aids tremendously in producing better transfer morphs ;-)
    eta: well I tried one of the scripts out with my theory for a project but it's a no-go. Apparently the other morphs in the G figures [because they've had the bones adjusted to those shapes] did not want to play nice with the script - at least not for what I was trying to do.
    However for what you made these scripts for, they work great! smiley
