DazToUnreal window not showing
![jimmyke](https://secure.gravatar.com/avatar/c02c98e8c43af143fa4f4bc7f40ef3cd?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fc02c98e8c43af143fa4f4bc7f40ef3cd_100.png)
Hello guys. I'm pretty much new here at this forum but i kinda have an issue with something in unreal engine. Just wanna check if it's just me or if i'm missing something here. My question is about the option under window ---> DazToUnreal. Whenever i hover over this option the tooltip is saying "Bring up DazToUnreal window" I know that within 3ds max or unity whenever u press a certain key or a certain button it does open a window with some options. Isn't it supposed to do the same with unreal? Because everytime i click this option it does..... nothing at all. Am i really missing something here or is this a bug or anything? Tried to re-install the plugin but still same going on.
Thanks for any help here explaining me if it's just at my end or if someone else is experiencing the same issue.
hmmm you are talking about the "daz side or unreal side?
if and you are using the pluging from daz not from unreal then the option will be under the tab "file"
Yeah i'm talking about unreal side. There's an option in there under window saying DazToUnreal that is supposed to bring up a window but it doesn't.
That's why wondering if i'm missing anything here or this is a bug or something.
hmm the buttom in the unreal side for now is just "for nothing", it's just to say which you have the plugging.all you have to do is just export the character to unreal using the pluging.
I probably left that menu in there by accident. There's Project Settings in the UE4Editor for the plugin, but not an interface. If you Send To Unreal, the UE4Editor should just start importing. If not, you can import the DTU file it creates. http://davidvodhanel.com/daz-to-unreal-starting-an-import-manually/
Hi :)
I shared a topic about that here : https://www.daz3d.com/forums/discussion/452926/daz-to-unreal-bridge-plugin-showing-problem-morph-exporting-fix
Thanks for the answers everyone :)
