re-install question - which CMS thing?
Diomede
did a fresh install
should I install the postgre database for CMS?
pros and cons?
719 x 170 - 36K
Post edited by Diomede on
did a fresh install
pros and cons?
you don't need any with valentina in them as it is now obselete
(unless you are running D|S4.6 or something)
thank you
Also, I believe that any of the highlighted Builds (in yellow) are for beta builds. "Public" = Public Beta, so you're not installing the officil release in those situations. To keep things more clear, deselect the various beta build options from view in DIM
with all the autofits and crossfits,
outfits are pretty much interchangeable, kinda makes cms moot point
and the meta data would need to be meticulous.
