To unroll a paper...
DUDUDUDU Posts: 1,945
A member asked a interresting question on Carrarators: how to deploy a paper roll (in animation).
Here the link towards the solution that I found but, do you know a better and perhaps an easier than mine ?
I need to do that for my film in progress.
Thank you in advance.
http://www.bond3d.byethost18.com/index.php?topic=155.msg829#msg829
    What about using bones?
  • DUDUDUDU Posts: 1,945
    I' m not specialized enough with the bones only to have a paper well rounded.
    To say the truth, I didn't try too much…
    I was just trying it, and I think your spline method looked better. Bones may be able to do something as well, but it would take a lot of them on a high density mesh to get smooth angles on the joints.
    The true problem with the splines in Carrara is that not only the selected points are turning, but the entirety of the spline.
    Do you think that one needs two or three parallel “skeletons” to influence all the width of the paper ?
    I will test the bones tomorrow.
    Thanks !
  • Design AcrobatDesign Acrobat Posts: 459
    I took this idea from an old William Vaughan Lightwave3D video on rolling and unrolling. My apologies in advance as the video is poor quality...Not thinking well today as I have a fever and didn't set the resolution.
    Can see the video here ( I reversed it in premiere pro)
    1. Go to modeler room - use a grid (16 lines for nice deformation)
    2. Use the deformation Bend matter back in the assemble room, go to the end of your play time enter 1440 (4 times it will roll around (4x1360)
    3. Set the limits lower end to 98, leave the higher end at 100
    4. Z axis if the grid is positioned like mine flat on the floor.
    5. Now you need to fix with a morph so the plane doesn't roll into one er plane, that is, it looks like it is rolling on itself rather than looking like a plane rolling up.
    6. Doesn't have to be much of a morph, just tilted in the model room in the same axis (Z) as the plane is rolling. That will give you the effect of a rolling paper or carpet.
    Again I apologize for the video quality, my mind is funky today with fever.
    https://www.youtube.com/watch?v=8QenAwNdnJ8
    He, that seems very interesting and precise.
    I will try to study that also tomorrow but I'm not sure to arrive there.
    I keep you informed for the results (if I don't have a headache myself…:-S).
    I wish you a speedy recovery and thank you !
  • DesertDudeDesertDude Posts: 1,238
    Design Acrobat, that works perfect! Instead of reversing it, you can just start with a large Bend Angle and keyframe the lower Limit (I'm sure it's the fever...)
    I had an immediate problem with texture stretching which left me stumped. I eventually used a Rectangular Layer in the shader room and applied it to a shading domain and that stopped the Bend Modifier from squishing the text (don't know if that is the correct way to solve that problem...). Here are the results:
    https://www.youtube.com/watch?v=jO0HlqtA7pI&feature=youtu.be
    DUDU_00001, I have attached some pictures, hope it helps. Just create a box with segments. Create a simple morph for it (see it rotated at a slight angle?). When you apply the Bend Modifier, the paper will roll into itself as Design Acrobat said, but applying the morph will prevent this.
    477 x 355 - 27K
    472 x 348 - 23K
    263 x 467 - 28K
    457 x 202 - 7K
    464 x 309 - 19K
    Great Job Desert Dude!
    Design Acrobat, that works perfect! Instead of reversing it, you can just start with a large Bend Angle and keyframe the lower Limit (I’m sure it’s the fever…)
    Yeah...that's my story and I'm sticking to it. :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,387
    edited August 2014
    Maybe I should revisit this using C8.5 softbody
    http://youtu.be/VNjopQ5zlpQ
    Excellent,
    No time to open my computer before this evening, but while waiting, can you say a little more about the morphing ?
    Thank you !
    edited August 2014
    Excellent,
    Thank you !
    Morphing is just the moving or rotating of vertices. You might here additional terminology used with DAZ or Poser models, but that's basically all it does - moves - rotates vertices
    Be in the Model room and in our case, have the flat box ready to go and ALL the vertices highlight - because we are going to be moving the entire box with by rotating it slightly (tilt) to get the effect of an offset 'rollup' like a carpet or paper roll.
    1, Create Morph Area - Give it a name always :)
    2. Create Morph target and Edit it
    3. Move the vertices . - In our case we move all of the object on a rotation or tilt.
    4. Click validate
    You're done
    I made another morph target that curls up the end just to show one can have one or many morph targets per object
    One can also save morph targets for the same model, so you don' t have to keep re-inventing the wheel (but must be identical model)
    You are probably thinking one could use morphs to open and close doors/windows or move lids etc and you would be right. Morphing is more than just making lips pucker and eyes blink on DAZ and Poser dolls.
    Note: the pics are out of order, but they are there matching the description in the instructions.
    236 x 182 - 14K
    253 x 267 - 20K
    228 x 72 - 6K
    743 x 430 - 40K
    822 x 386 - 48K
    Post edited by Design Acrobat on
    Hmmm… Big problem!
    I have deformations with axes X and Y (a beautiful spiral), but in all the cases, nothing doesn't happen with axis Z and it is this one which should work.
    I tested on other types of deformations and axis Z doesn't have any effect.
    I created a grid of 16 as suggested, which could be the problem ?
    Thanks for your explanation about morph target !
    Hi DUDU_00001,
    I have attached a few more pictures. In my example I was unrolling the object down the Y axis. The "tilt" morph needs to run in the same direction. Then, in the Bend and Twist controls set the Axis to Y. Hope that helps and sorry for any confusion.
    576 x 340 - 15K
    578 x 336 - 27K
    235 x 240 - 10K
    OK, solved!
    I had entered 1440 “twist angle” and not “bend angle”…
    It should be said that I have a French version, sorry.
    Now, that works with wonder, I will be able to interest me in the morph target.
    Super sympathetic both !
    Hello friends!
    Here the final result while following your ideas:
    https://www.youtube.com/watch?v=vcpbJweegbA&feature=em-upload_owner
    I can say that it is exactly what I sought.
    I believe that we doesn't know enough the modifiers of Carrara.
    If one of you could write a small tuto on Carrarators, they would be super !
    Still thank you !
    DUDU_0001, looks fantastic, glad you got it work!
    I was just finishing a quick tutorial in PDF form when I saw your success. Would you like me to send it to you?
    With pleasure!
    But you can also publish it on Carrarators, here the thread: http://www.bond3d.byethost18.com/index.php?topic=155.0
    and my e-mail: [email protected]
    Thank you in advance! :-)
    edited August 2014
    DUDU_00001, I posted the pages up on Carrarators. I hope it is clear - it's not very pretty...
    Post edited by DesertDude on
  • HeadwaxHeadwax Posts: 10,026
    Thanks so much for that, looks pretty clear to me , I'll be back with questions if it isn't :) seriously appreciate that
