Anybody recall the Poser fix to get Vicky 4's eyes to close ?
If you just use the basic out-of-the-box V4 CR2 the Open-Close Eyes dial doesn't work. I know the fix is a simple edit to the CR2 (something has the wrong sign)
I think it was posted at Renderosity but there seem to be problems with the forums over there at the moment. A link to the thread would be brilliant.
(the URL and details appear to be one of the few things I lost a few months ago when my HDD crashed)
Post edited by 3dcheapskate on
I filed tickets but they deemed it solved without fixing it because it works in DAZ studio but Poser and Carrara we are out of luck
you need to delete some deltas created by Powerloader to fix it
it breaks everytime you add new morph packages and run the bat file
I will try and find my thread
https://www.daz3d.com/forums/discussion/43187/victoria-4-2-eyes-wont-close-or-open-in-poser
the thread not my Carrara one
Thanks - Akin's fix from the RDNA foruns, that's the one I was after !
I fixed it by replacing the deltas with the ones on my Figures, Characters and Avatars book disc, not linking the thread because unless you bought that book not much help,
what you can do is unlink your library
install her fresh no morphs in a new runtime
copy those deltas over and replace the ones in your library
then remove the temporary library from your Poser library and add your original back
Note to self: Just found a magic set of google search parameters - v4 eyes close site:daz3d.com/forums/discussion/
Turns out that this is all academic. I just redownloaded and reinstalled all the basic V4 stuff - her eyes open/close properly even after running the Morphs++ batch file (which was the original cause of the problem, and after a couple of years I'd assumed would never be fixed. But i appears that it was.)
maybe that's why they closed my ticket
Maybe - but wouldn't it have been nice if they'd told you that it was closed because the problem had been fixed !
