Managing my libraries
in New Users
Hi all. I’m currently running Daz Studio 4.14 (64 bit) on Windows 10.
Over time I’ve accidently created multiple libraries, in physically different places on my hard drive. Yeah, I know, how stupid am I.
I now want to try and bring order to the madness, and try to organise my libraries into a single library.
Is it just a case of moving folders from the multiple library folders into a single folder, or is it not that simple.
Any advice would be greatly appreciated.
Thanks.
Do multiple libraries have content isntalled by Install Manager/Daz Central? If not then, as long as the folder that they use iss till available, you can simply merge the folders - everything else uses relative paths. If you have used different destinations for DIM/Daz Central over time, and still have the content isntalled, then you will need to update the destination path in DIM, select everything in the Installed tab, and then right-click and choose the option to reinstall all selected using the current path - I'm not sure if Daz Central has an equivalent feature.
Nice one. Thanks for the advice.
