How to install the bridge in Unreal Engine?
AlienRenders
I'm trying to use the bridge and I don't see it in UE4. I can export from DAZ, but it just saves some files. Anyone know how to install this in UE4?
edit: I'm building 4.26 and the plugin is made for 4.25. I found the github source.
If an admin could delete this thread, it would be much appreciated, thank you.
Post edited by AlienRenders on
Hi. I shared a post about that. Can you read.
https://www.daz3d.com/forums/discussion/452926/daz-to-unreal-bridge-full-materials-plugin-showing-problem-morph-exporting-fix
Thanks, but I was using UE 4.26. It won't build as is. You need to add another dependency to the plugin ("DeveloperSettings") in the build.cs file. And changing the UE version to 4.26 in the .uplugin file.
I am using 4.25 now. Because 4.26 is in Preview mode. Not finished. So plugins and engines not updated. I prefer 4.25 completed version and it works perfectly.
The version in Github should work with either 4.25 or 4.26 preview, but you do have to build it yourself. https://github.com/daz3d/DazToRuntime/tree/master/Unreal
Okay, i tried to use DaztoUnreal with 4.26 but it didn't worked. Version error. How can i build for 4.26 manually ? I didn't do that before i am only using for animations movies.
Unfortunately, it doens't look like they've pulled my changes for 4.26 yet. Can you access my fork? https://github.com/David-Vodhanel/DazToRuntime
There's some basic instructions for adding the plugin to your code build.
I tried all ways. But ue 4.26 giving error while opening project. (i don't know building etc.. ) But 4.25 working well. Oh David you are the guy who is developed DazToUnreal plugin right ?
I've built the 4.25 plugin for 4.26. You only need to do two things.
1. Open the .uplugin file and change the version from 4.25 to 4.26. This will remove the warning when launching UE4 that the plugin is the wrong version.
2. Open the plugin's .build.cs file and add "DeveloperSettings" to the PrivateDependencyModuleNames section.
That's it. It should now build with UE 4.26.
Assuming you can access it, my fork has the changes needed for 4.26. https://github.com/David-Vodhanel/DazToRuntime
I think these will get pulled into the main branch soon.
I made the original plugin and still contribute updates.
Thank you AlienRenders i did them all. and i downloaded from David's link and problem solved now :)
Thank you David this is amazing plugin. Especially converting materials are really great. Because if someone try to convert materials like this he/she must spend months for that its very detailed converting.
I have a question for smooth mesh. I am using maya for 4 years and i am using DaztoUnreal just for material converting. So i mean, firstly i import character to Maya, and animate, retarget, and last i am importing to Unreal. I dont using directly DTU fbx file.
I mean, the character's mesh from Maya is not smooth. Sharp corners on the mesh like toes and fingers not smooth mesh. How can i fix it ? DazToUnreal FBX importing very good. But manual fbx importing is not smoothing mesh. I selected all options for smooth mesh, tangents, normals etc..
Examples Below
If you use the Subdivision option in DazToUnreal, you can send the character with subd1 which will improve this. It works be forcing Daz Studio to export the subdivided mesh. The problem with doing this generally is that the extra vertices are exported without weight. So on import into Unreal, I try to calculate the missing weights. My maths not perfect yet, but it's getting close.
If you're using Maya in between, you have a couple options
1) You can subdivide the character in Maya. This might take a bit of fiddling. Things like teeth tend to get rounded off.
2) I think you can export the subdivided character and have Maya generate the missing weights. If I remember correctly, either the Maya or Blender bridge does something like this.
Also, I don't recommend subdividing the clothing or hair, as it can get very heavy.
I fixed it. Open IrayUberShader into Unreal Material Editor and Enable Tesellation > Choose PN Tesellation. All shapes turned smooth.
What do you mean by that ? Because I don't think I can.
Does this plugin require a purchase or not ? The Daz people seem to say it's free. Is only half of it free ?
It's all free. The changes are there and in Daz's repository. I think the latest version includes the files needed for 4.26 as well, I haven't verified though.
its not a so good practice selling the bridge in the unreal shop for 40 bucks though its free here
its the same thing Tsuba
how do you get this workign with 4.26? I've installed directly from DazCentral and that didn't work. tried the Git link above and now I get this error.
its not working with 4.26
read the forum what daz-_sam said
I had the same error.
Link
I found out a solution.
create a C++ project in 4.26
add the Plugin to a folder named "Plugins"
right click the uproject file and select "generate project files"
build the project in visual studio.
Do this every time there's an update to either the plugin and 4.2x
You can even build it for the chaos preview build of 4.26
So I couldn't find where you change the version number in step #1. I opened the .uplugin file, but I don't see where it explicitly says 4.25. I copied the repository from David's GitHub and even checked the .uplugin file preview in GitHub - it's not mentioned there either. Where exactly is the version change taking place with the .uplugin flie?
How did you find this? I can't find this detail in the .uplugin
Can you please attach a pdf or something on how to manually install the two folders. I've managed with unreal but don't know where to put the daz plugin folder :(
