Applying Preset Poses?
Under the "File, Save As" pull-down Menu, I find I can save a "Pose Preset." In my (ignorant?) little mind, this should mean I'm saving a pose for a particular Daz figure -- G8F or G8M, say -- and that I could then apply that pose to that figure type in future scenes/renders. To my way of thinking, this should be as simple as applying purchased poses to figures from my Smart Content pane. But I find no obvious way to apply a "Pose Preset" that I've saved to a given figure.
Well, sorta':
I tried using the "merge" pull-down menu -- i.e. to merge a saved pose preset on a figure -- and it posed the figure correctly -- but turned all the figure surfaces totally black.
Do I misunderstand what a "Pose Preset" is, from my discussion above -- or is it possible to do what I'm describing? If it is possible -- how is it done?
You should be able to aply them by simple double-click on the file in a content pane, but the method you are using should work.
