Eyebrows & Coloring
![Hexdrake21](https://secure.gravatar.com/avatar/50ac9fc8d83388a83eea224c4c831c07?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F50ac9fc8d83388a83eea224c4c831c07_100.png)
I have a Gen 8 female with skin shaded green. I made several modifications and got the face just right using orc fantasy morphs. Somehow during the morphs the eyebrow color became linked to the skin color, and I don't know how to change it back, and don't want to start over again. I know there is some option I am missing. I tried selecting things on the surfaces tabs, but don't see a way to display the eyebrows there. I KNOW I"ve seen these before. I tried loading other models, but with no luck, What are eyebrows under?
Do I select the brows under eyelashes in the menu above -- mods only seem to change the lashes. I don't understand the relationship between eyebrows and faces, and Google has failed in an epic manner.
Thanks for any help!
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/b4/d2d6441813f15d735c511cdcefe7f7.png)
Hello!
I also have issues with painted on brows on some of the textures but I found the Brow Remover and it takes a minute or so to run but works like a dream! It removes the painted on brows so you can use fibermesh ones and color them whatever color you need!
Elli
Thanks, MimicMolly & Ellindra! I used Brow Remover as you suggested and it works well. Does anyone have advice on where to get natural fibermesh brows? I bought Ulimate Eyebrows for Gen 8F, but they look more painted and I usually do fantasy renders where the characters would have more natural brows. Or maybe there's a setting that someone knows how to use the program?
https://www.daz3d.com/super-natural-brows-merchant-resource-for-genesis-8-and-3-female
https://www.daz3d.com/beautiful-brows-for-genesis-8-females
https://www.daz3d.com/luxe--fibermesh-lashes-and-brows
I have those 3 packages.
I use Super Natural Brows the most. I has the most options, thin, t.hick, brows projection. I use this when I want the brows to stand out.
I use beautiful brows on my glamour renders. These are a lot softer, however, the color option is a bit limited.
I got Luxe primarily for the lashes, but the brows are even softer than beautiful brows. I use these on Asian characters. The brow colors are also limited.
Thanks, JV! Put the natural brows in my wishlist -- hit my monthly budget limit today
so will try it next month. Looks like a good resource, though.
