Striations (SOLVED)
IkyotoIkyoto Posts: 1,159
edited January 2015 in Art Studio
http://www.daz3d.com/galleryimage/image/36829/g2-jess-01_425_auto.jpgG2F w/G6 mats. hate the stripes. any suggestions?
400 x 400 - 24K
Post edited by Ikyoto on
  • starionwolfstarionwolf Posts: 3,670
    edited August 2014
    edit: removed incorrect information. See Mr. Richard Haseltine's post below.
    Post edited by starionwolf on
  • Richard HaseltineRichard Haseltine Posts: 102,344
    Striations are usually down to shading rate or scale - given that you are fairly zoomed out, so that the figure is relatively small in the viewport, you probably need to lower the Shading rate a bit from the default. Make sure that you use the same value on all surfaces with the same Group ID or you will get unexpected results.
    edited August 2014
    Now I remember. We can adjust the shading rate and shading scale of the skin surface/texture.
    Thanks for the reminder Richard Haseltine.
    Edit: 111jack suggested lowering “Shading rate” from 6 to 2 and increasing “Shading scale” from 0.5 to 1
    Source: http://www.daz3d.com/forums/viewreply/457845/
    551 x 488 - 88K
