World-Space-Coordinate-System using setWSRot() has a wrong? outcome.
![madheadcrash](https://secure.gravatar.com/avatar/97e1256dff1b9dbcb255072a8b4277b0?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F97e1256dff1b9dbcb255072a8b4277b0_100.png)
Hello,
I don't understand the world-space coordinate system in DAZ3d at the moment. I searched in the documentation but found nothing what helped me so far. I hope someone can explain it to me.
I tried for some experimentations to set the left shoulder to -45° with the following code. I assumed the rotation would be given in RAD. Found nothing about the unit in the documentation. Maybe I searched in the wrong place?
I used a Genesis 2 Male for this.
QString lShoulder = "Left Shoulder";
DzNode *nodelShoulder = dzScene->findNodeByLabel(lShoulder);
nodelShoulder->setWSRot(DzTime(0),DzQuat(0.0f*DZ_FLT_DEG_TO_RAD,0.0f*DZ_FLT_DEG_TO_RAD,-45.0f*DZ_FLT_DEG_TO_RAD,true));
The outcome was as followed:
Twist: -5.99
Front-Back: -4.78
Bend: -75.0 (seems to be maximum)
After this I tried it without conversion to RAD
nodelShoulder->setWSRot(DzTime(0),DzQuat(0.0f,0.0f,-45.0f,true));
Twist: -0.13
Front-Back: -12.41
Bend: -75.0
I expected the outcome would be
Twist: 0
Front-Back: 0
Bend: -45.0
Why isn't it this way?
Hmm, I think you are using the wrong DzQuat constructor. Something like this is probably what you where trying to do.
Better would be:
Hi,
I just tested it. Your were right. I used a wrong constructor.
now It's working the way I had in mind.
Thanks for your help!
