uv maps?
konkon Posts: 389
what folder can fine the uv maps in?
  • Cris PalominoCris Palomino Posts: 11,602
    Are you asking because you want to texture something? Those are normally in the readmes. You can find them by getting the SKU number off the product page and then looking it up in the Product Index.
  • konkon Posts: 389
    I have product made for genesis but uses a m4 uv map i want change the map but it doesnt allow me.
    In D/S on the Surface Tabs, Genesis being selected, look for the uvmap drop-down menu. Select the one you want to use.
    n.b. that if the product uses the M4 uvmap, it is not going to look quite right with a different than M4 uvmap on Genesis.
  • konkon Posts: 389
    well I did try that but it doesn't allow me to change the uv map
  • Richard HaseltineRichard Haseltine Posts: 102,170
    It doesn't allow you to make a change, or there are no changes available to be made?
  • konkon Posts: 389
    It doesnt allow for changes
