Free Laptop Model
Hi, this is my first model which I made and textured in blender.
duf
duf
laptop.duf
6K
91 x 91 - 5K
  • Catherine3678abCatherine3678ab Posts: 8,387
    edited January 2021
    I see this is your first post so Hello and welcome to the forums :-)
    Thank you for the thoughts but this is not going to work.
    When starting out it is a good idea not to encrypt your files.
    In D/S - Edit > Preferences ... there you can set your "name" ... "anon" is not generally done.
    Under My Library > Runtime > Textures > name your subfolder ... having .png files in Hussein Saafan's Documents folder is fine on your computer, but nobody else's.
    After putting the required images in a suitable subfolder, retexture the model using them, then save it out again as a figure/prop, possibly to the location My Library > Props > {your name}
    When packaging up the freebie, you need then to copy everything into a set of empty folders using the same structure. This is then put into a .zip folder for sharing.
    My Library > Props > {your name or product} .....
    My Library > data > husseinsaafan > Laptop > Laptop > laptop.dsf   [without this file the .duf will not work]
    My Library > data > husseinsaafan > Laptop > Laptop > UV Sets > etc.
    My Library > Runtime > Textures > {your name} ....
    And then, people need to have a readme [text file] ... in order to use your model, they want to know if it can be used only for non-commercial projects - if it can be used commercially, etc.
    Welcome to the world of 3D modeling :-)
  • Thanks for the advice, I tried again following it, please let me know if I did anything else wrong.
    zip
    zip
    Laptop.zip
    555K
  • StargazeyStargazey Posts: 251
    You seem to have missed out the "textures" folder within the "runtime" folder.
    Keep up the good work. The first step is always the hardest!
  • Faeryl WomynFaeryl Womyn Posts: 3,658
    Keep going Hussein, you're doing well for a first model and Catherine is great at helping people.
  • Sfariah DSfariah D Posts: 26,519
    Looking forward the end result.
