Hot Key Commands not working?
DDCreateDDCreate Posts: 1,404
I just got a new keyboard because my Q died. It's the exact same make and model as before but for some reason, I can't get my keyboard commands to work. For example, SHIFT+Y to call up the tool to mirror a pose or CTRL+L to toggle screen lights. Maybe it has nothing to do with the keyboard. Maybe I accidentally switched something off in a menu somewhere? And yes, I checked to make sure the keys themselves work. The shdows in the picture are starting to become hard to work with. I have 2 Distant Lights that are on. When I turn them off, it's just black. Does anyone know what I'm doing wrong?
Thanks!
1464 x 997 - 194K
  • Do the shortcuts still appear next to the commands when you find them in the menu, or are they missing there?
  • DDCreateDDCreate Posts: 1,404
    Oh man. I'm sorry. I don't know :P I don't know where to find them in the menu. I saw those in a tutorial once, wrote them down and memorized them. I watched the tutorial again to see if I was remembering wrong or not. Where would I check that? Also...I noticed that when I select an item and hit the delete key because I changed my mind about using it, Daz doesn't recognize that as a command either. Not sure if this is a related issue or not.
    I haven't installed or uninstalled anything lately either. Not Daz, not anything. Maybe a at home gym but that was like a week ago and I doubt that was it. All I did was plug in the USB for a keyboard that didn't have coffee in the keys :P
  • If you open the Edit menu, having made a change to the scene in soem way, is ctrl Z listed next to Undo <whatever action>?
    No it is not. Sorry for being a dummy and having to have you explain that to me.
  • OK, in that case you either need to reload the layout (Window>Workspace>Select Layout) or at least reload the actions (Window>Worspace>Customise, click the Import.. button at the bottom, and select Actions, then select the defaults)
    BOOM! Nailed it! Thank you for the tip Richard, that was much easier than I feared it would be. I was sure I'd have to go back and set them up again manually or something. Just needed a quick slap on the box I guess.
    Thanks again for the help!
