Render question
in New Users
I might be in need for some help here.
Some times when I try to make a render of a scene I created, I end up getting a completely white pic. No figures, props or anything - just plain white. I have tried to make two renders located inside a room - and they both turned out that way when I did the IRAY render ?
The rendering starts out like normal - but instead of becoming sharper in the render proces, it becomes more and more grainy until it ends up completely white when the render is finished.
Any idea what I am doing wrong ?
If I construct a partial room (not all walls applied for a full room), I usually don't have problems when rendering.
Is your camera postion outside of a wall looking in?
It shouldn't be..... my view port shows the scene inside the room.....but maybe you have a point. I have not considered to check up if the camera is positioned outside while the view port shows the inside scene.
