Simple Room 3A... a simple room for simple needs.
Simple Room 3A
It can be found here:
http://www.ShareCG.com/v/77561/view/11/Poser/Simple-Room-3A
Just a simple room with a posable door (dial operated), separate walls that can be turned on or off (read the included "ReadThisToo" document to find out how to "turn on" a wall… and also what turns them off)… (mostly stuff like lying and hanging things with nails)… separate ceilings, separate light switch and outlet, and a small section of hallway.
1363 x 1138 - 345K
1363 x 1138 - 365K
1363 x 1138 - 352K
Post edited by McGyver on
Very Nice! I like the details and the fact that you included a hallway with it. Thanks!
Very nice... thank you. I was afraid to leave a rating at ShareCg because I always get it backwards... when it looks like you are giving 5 stars its a 0 rating and when it looks like you are giving no stars it says a 10 rating??
Thank you very much! This looks great!
Hi, thank you all for you kind comments...
Unfortunately something slipped by...
Simple Room 3A was missing "Glass_EnviroMap2.png"... I guess since it was already in my "Vix_CommonTex" folder, I failed to get an error message... I suppose that is an argument against having textures share a folder, although it saves the person downloading the model, memory resources... it makes it harder to check the model without testing it specially.
So if you downloaded it, you should probably download it again... I really hate when I mess up... I guess doing a couple of models at once can lead to mix-ups... Sorry.
This is a very nice room set. One thing that would make it better, though, is if it also included a straight section of hallway, not just the corner section. That way, you could link together multiple rooms side-by-side along a single stretch of hallway.
Simply fantastic. Thank you very much.
