Carrara 8.5 how to manually manage Daz Content
Zach WilsonZach Wilson Posts: 92
edited January 2021 in Carrara Discussion
I'm looking for tutorials on how to manage manually set up and manage Daz Content for Carrara.
Post edited by Zach Wilson on
    edited January 2021
    when you add DS library to your carrara browser tray, it's just called 'folder'.  not the same as poser runtime.
    the real trick is to know what daz content is combatible with carrara, since the store doesn't tell you.
    if given a choice of poser version or ds version, is usually wiser to use the poser version.
    if you're having trouble with a specific model, ask here in the forum.smiley
    Post edited by Mistara on
  • DiomedeDiomede Posts: 15,128
    I think @Dartabeck has a video detailing what he does.
  • Thanks for the feedback.I've never used content before and I would like to set it up my content without having to rely to much on the automation of the DIM.
    edited January 2021
    the trick to adding a ds content folder, you want to select the folder that contains the data folder in it,
    if you see the dsf not found message, it means it's not finding the data folder.
    and to preserve relative paths
    the data folder and runtime/textures folder needs to stay default paths,
    the rest of the folders, customize to heart's content smiley, not sure how the smart works, dont know if meta data stores paths
    i don't have the cms installed
    the ds data folder is similar to poser's geometries folder.
    422 x 352 - 40K
    174 x 204 - 16K
  • DartanbeckDartanbeck Posts: 21,328
    An article. It uses DIM, but the same can be done manually simply by opening the zip files and dragging to the proper locations, as you probably know. DIM makes it So Much Faster, however, since we can select large groups of items and install them to the directory we want.
    Anyway, here's my rambling on the subject:
    Daz Install Manager - Installing Custom Poser Runtimes
    Basic walkthrough of designing your own custom runtime structure
    While we're at it, this article may be of help to you as well. Once I optimize something for use in Carrara, I store it to Carrara's browser, and this details how I've set my browser up as a catalog of goodness!
    Your Carrara Browser
    Making great stuff isn't as cool if you can't remember where you put it. Let's get some good habits going right from the start
    Also about DIM:
    Let's say we decide that we want to remove items from one of our libraries and add it to either a different, or completely new one. In DIM, we just tick the items we want to remove and run the queue. Now they're either in the Downloads tab or the Install tab (Install tab if you don't choose "Delete after Install" option).
    Now we create our new directory, if that's what we're doing, tick all of the items we just removed, select the library we want (be sure "Show Details" is checked to see your list of directories) and run the Queue. So fast and easy - especially since each item we install goes to several places within the directory (hard to scrub them clean manually without opening the original zip to see where everything went, etc.,)
    I must say, with all of the negative talk preceding the release of DIM, I was leery to try it. I decided to give it a shot on a laptop that didn't matter - fell in love with the thing and have been using it to great effect ever since.
    I am a die-hard Carrara user, so when I get products that have both Poser and Daz Studio versions, I often hide the DS versions until I need them. DIM rocks for that too!
    Also, if we want to know where certain parts of a product is, simply open DIM, go to "Installed" tab, search for or navigate to the product, right-click > show Installed Files. It shows every file installed for that product. I want to get to the Textures folder quickly, so I click on it or one of the textures ad it opens the folder for me as well as showing me where it is on my drive! Love this thing!!!
    But that's just two cents. I understand liking to keep thing manual too. To each their own, I say!
    Cheers!
    Into learning about Carrara? Me too!
    Check out the Carrara Information page on my website. Links and topics, videos, downloads...
    It's a fun little place!
    or poser content.angel
    putting the birds together from the birds sets, can be confusing on the fly,
    taking the time to put the birds together and saving them to carrara.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,056
    edited February 2021
    need to turn off limits before loading the old Songbird remix birds or hip deformed
    the new updated ones from Hivewire3d can use the duf ones
  • Zach WilsonZach Wilson Posts: 92
    Here's what I've done so far. I created a place for my content C:\ Runtimes\V4, then I downloaded and unzipped the Victoria 4.2 base there, next I opened Carrara and went to the File/Folder icon on the browser tab but the option to add a runtime is greyed out. Obviously I'm doing something wrong.
    Nevermind I forgot to select the content tab first. She's loaded and everything is working. I'm sure more questions will follow later when I and more items.
    Not "wrong", you just didn't get there yet ;)
    For this to work, you simply have to have a scene open - even if it's empty. Just go to File > New and start any ol' scene, and your options will appear for you!
  • After reading the information in this thread again I decided to use DIM. I uninstalled Carrara then reinstalled Carrara and Victoria 4.2 with DIM and everythings works fine. Then I installed V4 Hi Res Shaders for Carrara 7 but it's not showing up in the content tab. I ran auto dectect runtimes again but no luck. Where should this have installed and am I doing something wrong.
    The hi res shaders are carrara files.
    they would go into your carrara library.
    there is a specific tab for shaders.  if you don't see the folder under the shader tab, you may need to 'add' the folder to your browser tray.
    1002 x 313 - 57K
  • Thank you very much. Never would have thought to look there I just assumed that it went into the content tab.
  • Bunyip02Bunyip02 Posts: 8,379
    In the event that they are Poser files instead of Carrara files, and if you installed using DIM, you can locate the files by clicking right mouse button on the item in your installed folder in DIM. Then left mouse button click on Show Installed Files.
    692 x 1031 - 138K
    Post edited by Bunyip02 on
    can you tell dim you want the poser version of downloads?
    i've never used dim.  i cant see the light gray font in prod lib.  i might have to dim sum.
    can it download files with the actual product name and not the im number.  i hate the im number, cant sort files alphabtically.  even better if can automatically extract all files, in folder name of the product.  doing it manually takes a very long time  doh
    thanks.
    Mystiarra said:
    1 - can you tell dim you want the poser version of downloads?
    2 - can it download files with the actual product name and not the im number.  i hate the im number, cant sort files alphabtically.  even better if can automatically extract all files, in folder name of the product.  doing it manually takes a very long time  doh
    thanks.
    1 - Yes, if there are separate files specifically between Poser (Ps) and Daz Studio
    Being a Carrara-only user for so many years, I formed a habit of selecting all DS verions of products, right-click > Hide Selected, which hides them so I don't have to install them to not see them. Easy peasy!
    2 - Well, it downloads what the files are named - but that's not what we "see" in DIM. DIM gives us the actual product name, which is then searchable. Very slick!
    In addition to Searching, the Installed tab (list of everything DIM installed for us) has several really handy list order criteria we can choose from, like Install Date Newest/Oldest, Order Date Newest/Oldest, Alphabetically, etc., etc., there's a few options in there.
    Searching is also a real breeze. I love DIM.
