Geoshells-how?
Hi,
I think I have a (basic) understanding of what geoshells are, but are they easy to make? If so how is it done?
Cheers.
  • lilweeplilweep Posts: 2,558
    you click the geoshell button and it adds one if that helps
  • SteveM17SteveM17 Posts: 982
    So I just select the object then create geoshell and that's it? (I never even  knew there was a geoshell button until you mentioned it).
  • onixonix Posts: 282
    Yes, you select an object and click create geoshell. that's all you need
    In some way, geoshell is similar to iray instance except that you can apply different texture and turn off  certain parts of it,
    usually, we use shells to add an extra layer to the figure surface as if you want to add dirt or wettness or tatoos
    Well, that was easier than expected! This will come in handy, so thank you for the info.
    Cheers.
  • Here is a good tutorial that OSO3d posted a while back:
    https://www.daz3d.com/forums/discussion/68454/simple-geoshell-tutorial/p1
