FM Tank Tops
Hello.
I am trying to use FM thank tops (http://www.daz3d.com/tank-tops-and-undershirts-collection) on a V4 character. The product is for Genesis but it says it has morphs to fit V4.
I only can fit the tank top on the character with mesh resolution and even with that the back is too loose, as the pic shows. How do I make the back fit in?
Has anyone resolved a similar problem? And if not is there any V4 tank top product out there (or sports underwear)?
Thanks in advance!
1422 x 800 - 947K
That means the V4 morph/shape as applied to the Genesis figure, not the standalone V4 figure as the geometry is different between them, even allowing for a similar end shape.
So there is no way to apply those tank tops on a V4 figure?
Not with any degree of ease. You may be able to get something not too bad if you coudl load and shape a Genesis figure to as close to your V4 figure as possible, load the top to Genesis and then save it out as an object or morph, then load that back and parent to V4.
Damn... Thank you anyway.
The tank might also have morphs (Don't know, don't have it)
but if you select the tank in the scene tab, then go to the parameters tab and check all the different categories there, you might be able to find something that will help the tank fit better.
The problem is the rigging, not the shape.
