Hi there!
I double checked with a few people to confirm there is no cutout opacity or transparency for the PBRSkin shader as it's meant for actual skin. If you want to apply transparency/alpha/opacity you'll need to use the Iray Uber shader system
Hope this helps!
Elli
Hi there!![wink wink](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/wink_smile.png)
Hope this helps!
Elli
Then I will use LIE in order to merge the layers and apply a mask to the maps on the top.
Geoshell can't be used with this shader when there is transparency.
