Hiding character temporarily in the scene
![julian_3946236](https://delorean.daz3d.com/forums/uploads/userpics/384/nUZOPWJ55UVVL.jpg)
in New Users
Is it possible to hide a character temporarily from the scene, on a keyframe, without having to remove it completely from the frame ?, I tried using opacity and n works very well, it seems that opacity n is an item to be observed within the timeline
You mean make it invisible during some frames? You could sale it to 0%, using the Timeline to make the interpolation constant so it would change isntantly to 100% when needed.
I think I must be doing something wrong, what is the difference between these three parameters?
Which three? If you are wanting to use an image, please attach it to the post rather than trying to embed the data - use the Attach a file link just above the Post Comment button.
I think I must be doing something wrong, what is the difference between these three parameters? (image)
How can I do so that the changes in a frame do not change all the behavior of the previous frames?
Those control which nodes are affected when you create a key frame - the whole figure, the current node and its children, or just the current node respectively.
You need to set the interpolation type to Constant
Thanks man, you are the best:)
