Zero morph on head only?
AlbiejeeAlbiejee Posts: 153
After dialing a whole bunch of full body shape morphs and character morphs. Is there a way to zero all the shaping morphs for the head or face only?
for Genesis or Genesis2?
  • barbultbarbult Posts: 24,863
    That's a really good question. I tried several things and nothing was successful on G2F.
  • FistyFisty Posts: 3,416
    Look at currently used morphs and zero out the ones that are head or face.. if it doesn't let you zero them out click on the gear, open the properties, and turn of limits.
    Little warning: if have, say, V6 applied and you turn off limits to remove her face morph and then decide you don't want her body you'll end up with her head at a negative value and you'll have to go in and fix it. The way around it is to dial your characters using the separate head and body morphs rather that the controllers that drive both at once.. but if you've already created you mixes it's too late now.
  • AlbiejeeAlbiejee Posts: 153
    Ya the problem I'm having is with character morphs that don't have a separate head dial. I wish there was a way to Zero Genesis by body parts not just full figure or by dials.
    Yeah Genesis 1 was really bad about that, G2 has been a lot better, very few I've seen that are all or nothing.
  • cecilia.robinsoncecilia.robinson Posts: 2,208
    Many products have reset options (expressions, partial expressions, poses, partial poses, head, body...). Aaand... Guess what? They work on everything.
