Help resolving poke through
sorakunosorakuno Posts: 69
I'm having an issue with the Genesis/Genesis Male 2 Pirate. It seems that no matter what I do the shirt sleeves poke through the coat sleeves when used with Genesis 2 Male and it's associated models. I've tried fitting it to different items and adjusting the sleeves themselves but there's still always a portion of the shirt sleeve visible, mainly in the shoulders and underarms that shows up even in renders. Does anyone know how to fix this?
  • Richard HaseltineRichard Haseltine Posts: 102,792
    Looking at the product list there appear to be some NS materials files for the shirt - based on prior experience I think they are No Sleeve, apply them and the sleeves will be hidden so that the poke-through doesn't matter.
  • sorakunosorakuno Posts: 69
    I was hoping not to do that because I wanted the cuff frills to show but if there's no other way I guess that's what i have to do.
  • kaotkblisskaotkbliss Posts: 2,914
    Are there smoothing modifiers for the coat? You can go to Edit -> figure -> geometry -> apply smoothing modifier to create one for the coat and have the under shirt as the collision item
    Or you might possibly be able to simply scale up the arm size on the coat a hair.
    edited October 2014
    I tired your solutions, unfortunately they didn't work. Wish I knew how they eliminated it in the promo render.
    Oh here's the renders
    Edit: Oh perfect, the sleeveless mat retains the cuffs.
    Sorry for wasting your time
    1272 x 648 - 552K
    1272 x 648 - 417K
    Post edited by sorakuno on
  • barbultbarbult Posts: 24,863
    edited October 2014
    All you have to do:
    Select the shirt in the Scene Pane
    Open the Surfaces Pane
    Click on Editor in the surfaces Pane
    Click the triangle by PrShirt to show all of the surfaces in the shirt
    Click the triangle by ShirtSleeves to show all the channels in the ShirtSleeves surface
    Click on Opacity
    Slide the Opacity Strength to 0
    Voila! Done!
    Edit: Oh, I see you got it worked out. Good!
    645 x 712 - 32K
    1698 x 1519 - 2M
    Post edited by barbult on
