The deffirence between saved as shader presets and as material presets
in New Users
Can someoen explain me the difference between the saved shader presets and material presets (I use shaders presets so I know about them) please?
A material preset is applied to a specific named surface (or several), i.e., walls, or torso, on an object or figure, usually with contoured bitmaps fit to the surface using a UV map. It will not apply to any other surfaces with different names. A shader preset can be applied to virtually any surface.
I see, thanks!
Is there a way to save both the morphs and the pose in a single preset?
File>Save As>Properties Preset..., you can then enable the tabs for the properties that you want.
