x rays
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
Hi!!! is it possible to do a shader style x rays, in carrara??? I don't have any idea to do that!!
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,380
    glow channel maybe on black bg
    semi opaque grey M4, V4 mouth eye bits full alpha with conformed skeletons using the glow?
  • rock livretterock livrette Posts: 53
    At least something close to it.
    Maybe a good base to do it lots better with a more sophisticated shader setup.
    Your turn :-) !
    600 x 450 - 23K
    1043 x 881 - 183K
  • laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
    thank you! that is ultra convincing!!! but I don't understand, in your shader, the "color" red mix!???
    well, 'til it works......
    Its an older test I did, haven't checked the settings again. Sorry.
    But: !
    just substitute the red color with a value 1-100,
    it still works. For subtle changes values work better anyway.
  • stu sutcliffestu sutcliffe Posts: 274
    edited October 2014
    Go here and look at this article on edge falloff. http://carraracafe.com/articles/10-reasons-you-need-a-falloff-shader/
    I think "Sparrowhawke" ( you will have to google it/him.) Has a free Edge Fall off shader on his website. It could add a bit of extra zing to the posts above.
    Edit . There is a link to Sparrowharke at the end of the article.
    Post edited by stu sutcliffe on
  • JamyJamy Posts: 192
    Hi,
    I think the best way for X ray is the plug Shader Ops from DIGITAL CARVER.
    http://www.digitalcarversguild.com/plugin.php?ProductId=11
    Very simple to use
    Jamy
    1000 x 901 - 149K
    800 x 1268 - 139K
    1500 x 788 - 481K
  • JoepingletonJoepingleton Posts: 746
    edited November 2014
    Thanks for the great information in this thread.
    This an experiment using Sparrowhawk3D's edge falloff shader [ http://www.sparrowhawke3d.com/Sparrowhawke3DLaboratory.html ] in Carrara 8.5 Pro to create an X-ray effect. I used a M4 skeleton and DAZ anatomy attached to a Genesis figure.
    405 x 720 - 58K
    Post edited by Joepingleton on
